Kaw-Prairie 650 with no LED screen display
I have a 2003 Kawasaki Prairie 650 with a problem with the LED read out on the dash board. The fuse is good, but when turned on or running there is no speedometer, odometer or fuel guage reading at all. The only light that is working is the neutral light. Any suggestions as to what I should look for to fix this issue? Thanks for your help.
Thanks for the suggestion. I disconnected the battery like you suggested, as well as all the wire leads, then reconnected everything. Still nothing. As I said before the neutral light comes on and I just realized that when I turn the lights on the backlight comes on the screen (for night viewing), but I still have no read out of the guages. Still searching. Please someone...help! Thanks!
Under the panel just below the throttle..on the right side of the airbox...where a gas tank would normally be
Help appreciated!! Have a 02 650 PRARIE and as others have experienced, I only have Neutral, Reverse and Backlight. No other data registering. Is there a fix? Thank you for your help. Yes I know old bike but is very low hours and 1 owner… not a suarine 🙂
