Can a Praire 300 4x4 tow my boat?
Old 04-18-2011, 01:20 AM
reddituser's Avatar
Default Can a Praire 300 4x4 tow my boat?
I have a 17' Whaler (925lbs) plus a 350lb motor; the specified towing capacity is 1100 on the Prairie 300, but I understand towing capacities are set on braking power. I just want to make sure I won't burn up a belt on my way out of the water. Only towing about 100 yards. Thanks!
Old 04-18-2011, 12:42 PM
Hayashi's Avatar
I think you can if the ramp has a good traction. I've seen boat dealers using a similare sized ATV to move their BIG boat/trailers around their shop. Just make sure you use your qaud is in LOW gear (if equipped) and 4x4.
Old 04-18-2011, 01:26 PM
420Pimp's Avatar
Give it a try 300cc is really underpowered honestly for half ton pulling... I wouldn't recommend doing this every time you need your boat pulled but once or twice shouldn't hurt.
TLC
Utility ATVs
09-16-2015 01:41 PM
carid
09-14-2015 03:40 PM
moneyrider
08-18-2015 07:15 AM
cornermike
05-28-2015 09:47 AM
xepathfinder
08-21-2000 12:03 PM
Quick Reply: Can a Praire 300 4x4 tow my boat?
