2000 prairie 400 4x4 cdi
This seems an odd situation as, when the CDI for late Honda 300FMs and 350FMs became unavailable, Honda sent out a "work around" consisting of a small piece of wiring harness and a different CDI, you plugged one end of the new harness into the old harness, and the other end into the new type of CDI.
As the 400 engine was used until quite recently, Kawasaki should be able to make a newer CDI fit, with a similar adapter kit.
Failing that, I have heard of people using a car DC ignition set up on a quad, the old 1980s style "contactless" systems with a distributor and magnetic trigger coil, could be adapted fairly easily, the few Chinese Quads which do use DC "CDI" ignition systems could too. The main problem being the power generated by the Kawasaki trigger coil may be excessive, also the timing and advance/retard curve may be wrong for your engine.
