Loud Clunk/grind on shifting
Old Feb 9, 2016 | 02:57 AM
JaemsChimney's Avatar
Default Loud Clunk/grind on shifting
While shutting from Neutral to any gear or Revers to High or Low and back there is a bit of a Grind and clunk, is this normal, (yes I make a full stop) it seems the idle is high some times and if lowered it would not be so bad.
just down want to mess this thing up, need it for plowing my big drive way
thanks
Old Feb 9, 2016 | 08:23 AM
Fasteratv's Avatar
thanks
Not sure which ATV you have but I'm going to assume its an auto, with a belt drive?.....let it warm up fully, then reduce your idle rpm's as you mentioned. ... This is often the cause of "grinding" when changing from forward to reverse...etc.
Old Feb 9, 2016 | 08:25 AM
LT80's Avatar
LT80 Expert
Have you cleaned the air filter? Possibly choking it thus raising rpm's a lil.
How about a good carb cleaning?
Old Feb 10, 2016 | 12:27 AM
Sorry I have a KVF700 Auto, will check the air filter and try to find how to lower the RPM's, thanks
Old Feb 10, 2016 | 12:51 PM
greg74's Avatar
Also, make sure you turn your choke off before you put it in gear. That raises your idle so your engine can warm up but makes it hard to shift out of neutral.
Old Feb 12, 2016 | 02:22 AM
it seems the idle gets higher after driving (snow plowing) it for a while (10 minutes or so), so maybe I have to turn the idle down after a bit of use?, Choke is off
Old Feb 12, 2016 | 07:55 AM
shovelryder's Avatar
Adjust your idle with the machine at operating temp.....anything below operating temp should idle higher with the choke.
Old Feb 12, 2016 | 03:34 PM
thanks I will try it
01ssreda4
Apr 27, 2018 09:44 PM
Ipmcelroy
34
Jun 25, 2016 04:37 AM
TaoTao110D
Mar 2, 2016 05:13 PM
Eggnog56
Feb 28, 2016 04:56 PM
Blake Prater
Jan 22, 2016 08:57 AM
