Correct Choke Spring Part # for 650 ??
Old Jul 31, 2002 | 11:03 PM
alltoys's Avatar
jefffoxer have you attained the new springs as of yet. I have installed a new set of springs along with the updated cable and have had no more troubles. The springs are from a Kawi bike KLR motocross bike which are longer, thicker should work for you. Let me now if you need the numbers still.
Old Aug 1, 2002 | 09:36 AM
jefffoxsr's Avatar
No I don't have the springs yet. What are the part #'s please?
Thanks.
Old Aug 1, 2002 | 11:29 PM
alltoys's Avatar
jefffoxsr Hey younge fellow here are the numbers although might be different that Nyroc's but these are from a KLR bike from Kawi what size of bike I'm not sure but work great. These springs you realize fit behind the rubber of the plunger so you have to pull the boot off the plunger to see the springs. These are longer and larger but work great.
16C063
92081-1720
spring, plunger
If you can get some amsoil lube for the tube you wont get any hang up as the weather changes and will work down the minus temperatures. Have fun :}
Old Aug 2, 2002 | 09:44 AM
jefffoxsr's Avatar
Thanks for the #'s. I have my springs out already. Did you replace the plungers too?
Old Aug 3, 2002 | 12:07 AM
  #15
alltoys's Avatar
Nope, the plungers are okay just make sure you lube the tube before assembly with a synsthetic lube is the best if not a light oil will do.
Old Aug 4, 2002 | 01:55 PM
  #16
roscoe69's Avatar
well here is a update on choke spring as i promised. Ended up looking for a new source and found Dynaline part # 24562 This spring is a 1/4" x 1" x .035 compression spring .This spring takes twice as much force to compress then the kawi spring. ( available from most hardware stores, bought mine @ackland granger in canada , granger in US ) 4 to a pk. aproxx $ 4.00 cdn .take the time to check out cable to make sure it will slide freely, should lube and adjust when you get in there.
raymond
GregM
Mar 6, 2018 06:53 AM
clsharky
Jul 13, 2015 02:07 PM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
