Swing-arm for MOJAVE
Old Nov 18, 2002 | 10:09 AM
mojavekid13's Avatar
Default Swing-arm for MOJAVE
Does any one knwo where to get a extented one buy liek 2 inch or so? and if so where at and how much? thanks guys
Old Nov 18, 2002 | 08:31 PM
rx7351w's Avatar
I bought an extra swingarm so I could cut it and make it longer. Where can I cut it to extend it? I'm guessing between the shock mount and the axle carrier. How much should I extend it. I ride trails mostly if it matters.
Thanks
Old Nov 18, 2002 | 08:38 PM
Well iam nto reall ysur ewhere to cut it! and i wouldent go any mroe then like 2' or else you are gonna bend it!
Old Nov 18, 2002 | 11:02 PM
albaBANSHE's Avatar
i have a +7in mojave swing arm with a fox shock but i dont think i wanna sell it
Old Nov 18, 2002 | 11:51 PM
rx7351w's Avatar
albaBANSHE on your swing arm is the shock longer? is the shock mounted the same distance from the swing arm bearings as a stock one?
thanks
Old Nov 19, 2002 | 12:38 AM
albaBANSHE's Avatar
no no no, this is a much larger shock and i welded square steel tubing where the shock mount bar is, i cut it in half andstuck 7in of tubing in between the cuts it is welded but i took some 1/2 steel plates and reinforced the welds and the bar where the custom shock mount is, i would send pics but no way to get pics on net so ? it worked well! oh and you will want to gear differeint and bigger chain
Old Nov 19, 2002 | 07:31 AM
Why do u not want to sell it?? an what kind of shock do u have on it? liek what is it made for!? and doesent it look weired on the mojave?
Old Nov 19, 2002 | 01:54 PM
jeffksf3's Avatar
I have a extra stock swing arm I would be willing to sell, make an offer.
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
RidE
Oct 19, 1999 06:10 PM
dunc_n
Aug 26, 1999 09:32 PM
BlackHawk
Jul 31, 1999 01:31 AM
