4WD not engaging, found the fix!!!
Old Mar 4, 2003 | 01:47 PM
  #41
altakawi's Avatar
Default 4WD not engaging, update and more help
I Had nothing acting funny what so ever,it just seemed everytime i went for a ride it would quit working ,then the next time it would work again.Then finally it quit working all together ,the moisture would get in the sensor and quit working then after a few days in the garage it would dry out and work again ,until it finally quit working all together. I talked withe my dealer and he steered me in the right direction. It is a real easy fix,let me know how you make out and hope this helps ,I am 90% sure this is your problem
Old Mar 23, 2003 | 01:11 PM
  #42
Scooter650's Avatar
AltaKawi, thanks for the help, got the speed sensor in from Ron Ayers late last week and put it on yesterday, it was the fix!!! Backed it off the trailer and played in what is left of the 4 feet of snow we got last week, what a blast.
Thanks again for everyones help.
Old Mar 23, 2003 | 02:11 PM
  #43
SandBags's Avatar
Default 4WD not engaging, found the fix!!!
Good deal, glad you have your Quad working again and it didn't cost an arm and a leg.
Old Mar 23, 2003 | 07:28 PM
  #44
Scotia650's Avatar
Nyroc,
I quess I should have stuck with my initial thoughts in January. If I had of stood on my bet, maybe you'd owe me a drink. [img]i/expressions/face-icon-small-wink.gif[/img] Anyway, good to have you back in the 4wd club Scooter. Happy trails, enjoy. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 23, 2003 | 08:11 PM
  #45
Ginchy's Avatar
The best oil ive used in the front diff is Lucas Oil. It shifts smoothly and without hesitation
The four wheel never worked better.
Old Mar 23, 2003 | 09:19 PM
  #46
Scooter650's Avatar
Yep, Scotia, you were right, the only catch is that there was nothing wrong with the speedo, it was functioning correctly. Either the speed sensor does not send that info, or that function was OK. Wish I would have tried it sooner, but the manual does not direct you there either. The manual lists an order to check things, and the one that kept stopping me was the incorrect power supply to the controller and no where does it say the speed sensor might cause that! Only references ignition switch, wiring, or fuse! Tried it all, but that is the first part I replaced besides a fuse.
Old Mar 24, 2003 | 10:08 AM
  #47
Scotia650's Avatar
Scooter,
It's just good to be going again, I bet. Not an expensive or hard repair either, got to love that. [img]i/expressions/face-icon-small-smile.gif[/img]
Maybe the intermittant signal was enough for the speedo but not for the 4x4. Either way, the main thing is it's fixed. Enjoy, mud season is here. [img]i/expressions/face-icon-small-happy.gif[/img]
blueandy88
Aug 31, 2015 12:42 PM
Polaris5
Aug 29, 2015 09:11 PM
GirlsCan2
Technical and How-To Articles
Aug 27, 2015 02:58 PM
mbkirk
Aug 14, 2015 08:20 PM
