Rear Gear Oil For KFX-700
Old Feb 28, 2004 | 05:35 PM
STAKK's Avatar
Default Rear Gear Oil For KFX-700
FYI, The Kaw wet brake oil IS Mobil 424 just in a Kaw bottle, there are cross reference's though, as they mentioned the Citgo oil in the manuel.....bottom line is ANY tractor transmission hydraulic fluid will work AS LONG as it is APPROVED for wet brakes.....be sure to look for the wet brake approval, about any tractor supply or garden center or even auto parts store should have it or be able to get it..........
Old Mar 2, 2004 | 04:45 AM
Snug's Avatar
I changed the front and rear gear oil in the Kodiak (94) tonight. How can you tell when it's "full"? I don't have a manual for the specs.
Thanks
Doug
Old Mar 2, 2004 | 11:13 AM
Pistonman's Avatar
Don't use THF in the Kodiak unless specified by Yamaha. You probably need to know the proper amount (usually in cc's) no check hole? Most quads don't have one.
Old Mar 2, 2004 | 12:51 PM
Snug's Avatar
No check hole. What is THF?
Thanks
Doug
Old Mar 3, 2004 | 01:24 AM
  #15
Pistonman's Avatar
Tractor Hydraulic Fluid--That's what V-Force rear takes(wet brakes)
ghost civic
Jan 15, 2020 07:43 AM
greg74
Sep 10, 2019 03:03 PM
WilliamBos
Jul 13, 2015 02:11 PM
rcappie4
Jul 10, 2015 04:54 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
