650 PRARIE PROBLEMS
Old May 17, 2003 | 10:59 PM
Scotia650's Avatar
Default 650 PRARIE PROBLEMS
If it was a problem with the tranny failing then the bike wouldn't run at all or at least any movement would make a heck of a racket. He's talking about 4wd not engaging properly and I think that is an unrelated problem.
Old May 18, 2003 | 09:38 AM
boss1quad's Avatar
It's definitely the tranny. If you're lucky it will unjam and you can use high range otherwise it's a tow job. The motor/tranny have to come out to the bench to redo them.
Old May 18, 2003 | 05:33 PM
NovaKaw650's Avatar
Originally posted by: Scotia650 - If it was a problem with the tranny failing then the bike wouldn't run at all or at least any movement would make a heck of a racket. He's talking about 4wd not engaging properly and I think that is an unrelated problem.
You're right, Scotia650. ROPADOPA's problems are somewhere between the 4x4 actuator/servo and the controller. He'll have to go through the testing procedure in the service manual.
Old May 20, 2003 | 09:07 PM
chop's Avatar
i have this little problem when i put my bike in gear,forward or reverse,i sometimes have to tap the throttle alittle to get it to go into gear,but not always.is this my linkage or is this common?
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
