Peaces 150CC Sport ATV
wiring again Lynn
Well, been just about a year since "the boy" has tore that thing up...he said he was haing some problem with the battery making noise, yep, sure enough...I was gone. The brackets had broke off and batteruy, box was gone with the battery. so..the wiring that goes to the battery were ripped off. Where do these wires go..believe there are four.
There is a big red wire (8 or 10 gauge) that goes to the starter solenoid input screw post from the battery (+) terminal. There is a big green wire (8 or 10 gauge) that goes from the battery (-) terminal to the engine frame somewhere near the starter motor.
A much smaller red wire comes off the battery positive post and goes to a 10 amp in line fuse very close to the battery. The other side of this fuse goes to the ignition switch.
That is three wires, not four. But I think that should be enough...
09-30-2015 01:37 AM
