help eton 90r problem!!!!!!!!!!
Old Aug 30, 2005 | 08:26 PM
atvrme's Avatar
Default help eton 90r problem!!!!!!!!!!
my buddy has a eton 90r and every time you put it in gear it die's , when it dose this it lose's spark but it will run all day in neutral.
if some one has had this problem please reply.
Old Aug 31, 2005 | 12:55 AM
spike99's Avatar
Answer might be in the following previous post....
http://forums.atvconnection.com/mess...y&keyword1=90r
Hope this helps...
Old Aug 31, 2005 | 10:26 PM
atvrme's Avatar
thanks spike thats what it is doing and again thanks!!!!!!!!!!!!
Old Sep 1, 2005 | 07:45 PM
kawieman700's Avatar
I'am a dealer for eton this is what i want you to do turn the key on w/out starting the bike hold the left brake and shift to F & R slowly put your head down by the floor board and listen for the shift motor to shift while you move from F to R if you can hear it working then it's iether the cdi box or the switch on the handlebar but if you do not hear it shifting back and fourth then it's your shift motor. Good luck hope this helps.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Ramman1
Jun 16, 2016 09:07 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
