Messed up the carb. on KFX 80/LT 80
LT 80 Iam in Apache Junction, Arizona which is about 20-25 miles from Phoenix, real close to Mesa, Gilbert, Chandler, Scottsdale, and other surrounding cities, are you in the Phoenix area LT 80? Weather is starting to cool off out here desert riding season is here, as well as Dune Season, Kawasaki shop where I bought the bike said they would only charge me $65 for the 1 hour labor to tear it open and track it all down.
Originally posted by: LT80
Sent PM, lemme know if it don't go thru. [img]i/expressions/face-icon-small-smile.gif[/img]
Sent you a couple PM's, not sure if they are going through.
I've sent a few to others, who have not got them....gggggggrrrrrrr
Blazin,
Take it from a former rookie, and a still learning guy. I was leary about doing all this stuff also.
These things are pretty easy to work on though.
I've got one completely tore apart and need to put it all back together after my motor gets back from Jack.
That will be fun, hehehe.......
As mentioned earlier, get a manual, it really does help.
Taking the carb of is really simple, you might just need to get a regular size philips screwdriver that has a skinnier shank than normal, it needs to fit through a hole. You will see the two screws you need to take off.
Jack will give you lots of good info.
Good Luck
Hi LT 80, There was an error on the page and could not recieve your message, I guess I will be taking it to the shop today, they said my boy will be ready to ride by Saturday, any other questionds I will be sure to ask, oh ya before all this notice the little 80 had fluid coming out the pipe while my son was riding I was behind and saw this is it normal, the bike is only 2 weeks since I have gotten it so I just have them check it. Jeff
#16
Just an update, Got the call on Saturday the 80 was ready asked the guy where they found the washer and the needle, and he said the needle was at the beginning of reed cage and the washer was a 1/2 in. from entering the motor from the reed cage. LT 80 I wrote your daughters number down in case I have other ?'s in the future. Thanks for all help.
Scooter's Shop
23
10-22-2015 07:04 PM
