3 SUNL 110cc Mini
Old May 21, 2006 | 09:49 AM
pemad's Avatar
Default 3 SUNL 110cc Mini
New update. The tire bead sealer works great! Goop the stuff on and bang you have a good seal.
Ran into an issue the other day. The rear axle bolts backed off. There are 2 of them that hold the sprocket in place. Dang things backed off and the chain started eating into the frame. Caught it before too much damage. I put them back on adding lock tite.
Another note is folks are right about the gas lines. They bite and start leaking after a while. Replaced the lines and filter. Used 1/4" blue stuff for snowmobiles. Seems to work good.
I have to say if you are not mechanically inclined don not buy the SUNL ATV. They need a lot of wrenching and inspection after every ride. Sometimes during the ride.
Here is what I check and tighten before each ride. I feel these are a must as the kids can get hurt without checking.
- Inspect axel bolts.
- Check chain tension.
- Check and tighten front suspesion spindals.
- Inspect gas line.
- Check oil level.
- Check steering bolts (ones holding the steering shaft)
Enjoy
Old Dec 13, 2006 | 01:06 AM
DSharp's Avatar
I'm in the process of buying 5 of these SUNL 115CC .
What is the average price?
I'm getting these for $1750 shipped
let me know what ya'll think
Old Dec 13, 2006 | 10:50 PM
pemad's Avatar
Sounds like a good price.
I assume the price is for all 5 of them.
I paid that much for the 3 I bought.
Just remember these are not Jap bikes and will need a lot of TLC.
I work on my kids bikes all the time.
Old Dec 14, 2006 | 09:27 AM
billl2099's Avatar
DSharp, hope it's not off of e-bay on a second chance offer, sounds like a scram, even for sunls, let us know if this happens.
Old Apr 22, 2007 | 01:37 PM
  #15
pemad's Avatar
Update on the ATV's.
Pulled them out of winter storage and charged the batteries and fired the machines up.
No issues yet and kids drove them for 30 minutes.
Next task is change the oil, check all bolts and give them a bath.
Not a bad machine for the price, so far.
Old Jan 14, 2008 | 10:46 AM
  #16
mlong's Avatar
Bought one for my daughter at Christmas. Tough little machine. Like everyone else I have checked nuts and bolts before every ride. The only issue I have found on this one is the carb leaks gas out the air filter when it has not been run for a few days. Last weekend I took my daughter out to a atv track and let her ride with other kids. All the kids were riding sunl 110 and here is what I observed on one who wrecked. These little kids need to understand that when they stop not to jump off not using the brakes. One kids jumped off while it was still rolling and the 4 wheeler run off a 2 foot drop and flipped over. We went over and rolled it back over and I noticed the frame was broke on the right side at where the rear swing arm connects to the back of the motor in 2 places. So I suggest to check the frame also prior to them riding if the get a little rough or hit something hard. Another thought on the tire issues everyone is having is go to Tractor Supply and get tubes for the tires. You can run lower air pressure and not worry about the tires popping off the beads.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
wrencher82
Sep 28, 2015 10:02 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
MrTrashMan2U
Sep 9, 2015 11:44 AM
Atvnewb88
Aug 13, 2015 06:48 AM
