HEY MR. LT80!
Old May 16, 2006 | 07:39 PM
dodgefate's Avatar
Default HEY MR. LT80!
well it seems that you seem to be the man on this page so can i bother you for a cuple of things? the rolers in the clutch whats all this talk i hear about them? from what i get you remove a cuple of the rolers and it makes the clutch engage at a higer rpm this giving it more umph? so if this is the case i see that you have pm'ed people the directons for doing this before, what would it take to get some of your expert knowlege on this?
Old May 17, 2006 | 01:03 AM
dj250r's Avatar
try not to remove them just get lighter rollers
well thats what we do on the kasea/ eton bikes
im sure Jack will chime in on this
Dwayne
Old May 17, 2006 | 10:51 AM
LT80's Avatar
LT80 Expert
No roller options DJ. We drill/remove to achieve the weight desired. [img]i/expressions/face-icon-small-smile.gif[/img]
Yes you can remove 2 w/o problems. It will be as you stated.
Remove the footpeg bolts and flip them foreward. remove the skid plate. Remove the clutch cover bolts (don't forget the bolt at the 3 o:clock position on the small cover)
A impact wrench is usually used and remove the front clutch nut. Remove the front clutch. You can then get into the variator and remove 2 of the rollers. Clean all parts.
Use 1/10 of the grease that was in there (I use a Q-tip of grease). Make sure the lil keyway is aligned and put it all back together.
Have fun. [img]i/expressions/face-icon-small-smile.gif[/img]
Bob E.
Oct 1, 2019 09:08 AM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
