LT80 Easy way to take off Carb
Old Apr 3, 2007 | 02:49 PM
LT80's Avatar
LT80 Expert
Default LT80 Easy way to take off Carb
Jetting isn't it. [img]i/expressions/face-icon-small-sad.gif[/img]
I get my carbs from Zuki.
I know I'd be switching carbs to see first.
Old Apr 3, 2007 | 05:02 PM
Kevdawg62's Avatar
i was reading another post you mentioned when you clean the carb to take out the needle seat and clean it.
Is that under the main jet with the o ring between the two? If so how do you get that out to clean twist pull yank?
i see it but wasnt sure if it's made to come out.
Fine I won't change the Jet I will. I will switch the carbs after this trip.
Do you think compression would be a factor at all and what do i need to test compression is it a special tool and do i pump the cylinder full of air or crank it over while this tool is hooked up?
I know i'm asking alot of questions but, someday Lt80 wont be here and we will need to fill his shoes.
Old Apr 3, 2007 | 07:22 PM
LT80's Avatar
LT80 Expert
Compression could be a possibility.. You need a compression tester. I got mine from Sears. You screw it in the plug hole and with the throttle wide open you crank the motor till the guage peaks.
Maybe someone has one you could borrow.
The float needle and seat are under the float. Pull the float pin and remove the float and you'll see the brass seat.
I never pull that o-ring out from under the main jet.
Ask anytime. Happy to help.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 7, 2007 | 12:50 AM
billyboys's Avatar
I has simmiler problems last year ...I cleaned entire carb 3 times BUT I did not clean pilot jet...so...I cleaned pilot jet and it runs like brand new....Just a thought
Old Apr 10, 2007 | 03:29 PM
  #15
Kevdawg62's Avatar
Okay well I went on my trip and we had a good time but here is the damage report. The lt80 that was working when I left stopped working after the 1st day. I think its a plug cap problem or coil, because the coil also has a crack in it. The one that didn't work when we left started up and ran okay. I just had to keep the choke on and lock the throttle down so they couldn't go very fast otherwise it would stall. I'm giving up on the lt80 that doesn't work, and I'm just going to work on the one with the carb problem, I've ordered a carb once it comes I'll let you know the news.
Also the water pump seal on my lt500 went out so I had to strap on a jug of water every ride we took, sometimes I just want to get all brand new quads.
Old Oct 21, 2008 | 01:46 PM
  #16
Twin LT80's's Avatar
Default LT80 Easy way to take off Carb"></title><script src=
While awaiting an answer to my other post, I've been doing some deeper reading on the LT80's in general. I just wanted to post a trick about the LT80 carb bolts that I did not see in this thread.
This thread covers tricks on how to remove the carb bolts. Once you have done so, I recommend NOT using the original bolts to remount the carb.
Instead purchase some Socket Head Cap Screws (S.H.C.S) of the same size and length as the original bolts. I bought a pair of stainless steel and they have saved me a TON of aggravation when needing to access the carb. I found the originals the most frustrating part of the entire removal process!!
The advantage here is socket heads use Allen keys. From this point, you can purchase a socket with the right allen key on it (which I did, but of course cannot find now!!) or use a standard Allen key. You may need to trim just a bit off the length of the long side of the key in order for it to fit w/o hitting the front framework.
You still utilize the access hole on the left side bolt just as you would have with a screwdriver.
Have fun!!
GregM
Mar 6, 2018 06:53 AM
timster911
Jul 13, 2015 01:57 PM
Wnthunting
Jul 9, 2015 03:02 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
