LT80 won't start
Old 05-29-2007, 11:06 AM
bigdumbfun's Avatar
Default LT80 won't start
We've only had this quad for about a month but my son loves it. It is his third quad and by far his favorite. It is a 1999 so it is a bit old but it has been starting easily and running good every time until now. I just get a faint click on the starter. I put a charger on the battery and it shows the battey as good. I have wiggled random wires etc. with no luck. This thing needs a pull starter. I'm glad this didn't happen 5 miles from nowhere.
Any words of wisdom? Thanks.
Old 05-30-2007, 12:38 AM
jr warren's Avatar
i would first check the solinoid by jumping across the two main wires and if the starter still just clicks then probley the starter has worn out and check all cables and ground connections before getting a new starter loose wires and cables are normal problems
Old 05-30-2007, 04:54 AM
bigdumbfun's Avatar
i'll do that in the morning. Thanks
Old 05-30-2007, 09:56 AM
LT80's Avatar
LT80 Expert
If it only had a solenoid...
You can stand the machine on end and put 12 volts right to the starter to check it.
Old 06-01-2007, 02:08 PM
bigdumbfun's Avatar
Just an update, It turns out that the kill switch in the back for the leash had wiggled loose just a tad. I pushed it back in and the quad fired right up. I think I am going to eliminate that switch all together to avoid future problems.
yagerzzz
06-24-2015 07:45 AM
clsharky
06-08-2015 11:38 AM
Dieseltrash
06-06-2015 09:53 PM
1000gade
05-27-2015 12:37 PM
Lasher
06-08-2000 11:43 AM
Quick Reply: LT80 won't start
