suzuki lt 80 weak spark
Old Jul 6, 2007 | 10:36 PM
qsportgoat's Avatar
Default suzuki lt 80 weak spark
87 lt 80 has very weak spark when testing coil or stater? already replaced stater but was used. any ideas please
Old Jul 7, 2007 | 01:21 AM
chabat's Avatar
I have a 1988 Kawasaki KDX200, among other bikes. On a spark tester, the spark looks weak, much weaker than any of my other bikes. I tried everything, stator, coil, CDI.
Let me back up... The original problem was intermittent "no spark". I got a stator from RickyStator.com... and then no more intermittent spark.
Even after a new stator, the spark appeared weak. But it has never failed to run.
Another problem I was having was poor fuel delivery, caused by some trash in the in-tank fuel strainer. I got a clear fuel line and that help me to see at a glance if fuel is getting to the carb.
What is my point? That it may run just fine with a weak looking spark... And that fuel delivery should be thoroughly checked before buying electrical parts. they are expensive and most times non-returnable.
I also had a briggs & stratton go-kart engine with a weak looking spark that runs great.
I know all the troubleshooting manuals say the spark needs to be blue and fat.... But make double sure about your fuel before you try buying other parts. You can put some gas in the spark plug hole, spray starting fluid in the intake, check the plug, is it wet? Is it dry? Get a clear fuel line, is there fuel in it? Take the jets out, are they clogged? Is the float sticking? I know that is a lot to digest... But keep us posted! And good luck!
Old Jul 7, 2007 | 09:15 AM
LT80's Avatar
LT80 Expert
Did you sand the stator and flywheel to remove dust/dirt/grime?
Old Jul 7, 2007 | 10:43 AM
qsportgoat's Avatar
thanks for getting back. carb has been rebuilt but i stiil made sure its getting gas even tried a little gas in hole. plus the plug was wet before. i have had a problem before and it was the stater,after it was replaced, the spark was big. but now with this prob. its weak and sometimes not there. tried new plug no diff. i followed the wires, ground is ok even pulled off the rotor and sanded the stater etc. maybe i will pick up a book to check what the #s should be on the meters thanks again
Old Jul 7, 2007 | 10:47 AM
qsportgoat's Avatar
thanks for replying. yes i tried that but no go, although it was dusty. im going to try it again and double check all wires.
Old Jul 7, 2007 | 03:36 PM
chabat's Avatar
<a target=_blank class=ftalternatingbarlinklarge href="http://www.rickystator.com/catalog/product_info.php?manufacturers_id=12&products_id=1 23
">http://www.rickystator.com/cat...products_id=123
</a>
rickystator.com sells LT80 stator assemblies. And they will re-wrap the one you have if that is what you want to do.
You can check your stator with an ohm meter.
Old Jul 7, 2007 | 05:18 PM
qsportgoat's Avatar
thank you chabat
Old Jul 8, 2007 | 10:54 AM
LT80's Avatar
LT80 Expert
If I remember right, the stator reads 175-185
Old Jul 8, 2007 | 10:19 PM
qsportgoat's Avatar
thanks ,ohms? when turning over ?
Old Jul 8, 2007 | 11:40 PM
chabat's Avatar
Nope... You use the ohm meter just to check resistance... Not when it is turning over.
