suzuki lt 80 weak spark
Old Jul 9, 2007 | 10:54 PM
qsportgoat's Avatar
Default suzuki lt 80 weak spark
OK, THANK YOU I CLEANED THE STATOR AND ROTOR AGAIN NO GO. I'LL CHECK THE RESISTANCE
Old Jul 10, 2007 | 11:01 AM
Fulltiltrider's Avatar
Its probably just your coil wire
Old Jul 10, 2007 | 08:45 PM
qsportgoat's Avatar
THANKS i'll try it!
Old Jul 10, 2007 | 10:33 PM
qsportgoat's Avatar
tried new coil wire , NG. spark is intermitent
Old Jul 10, 2007 | 10:36 PM
  #15
qsportgoat's Avatar
resistance is 320 ohms at stator and 800 ohms at coil
Old Jul 11, 2007 | 08:21 AM
  #16
Sounds like it could be your cdi then. Im not sure of the stator #'s for ohm readings, those readings seem a little high on the stator,but you said you already replaced that before right. How long ago
Old Jul 11, 2007 | 09:29 PM
  #17
qsportgoat's Avatar
i replaced the stator and rotor 6 months ago but they were used . i think i should replace them again, along with the coil assembly. there is no cdi unit, i think its part of the coil assembly. the coil on this is larger than my 230. thanks for your help!
Old Jul 12, 2007 | 11:03 AM
  #18
LT80's Avatar
LT80 Expert
I think you should call a Zuki dealer and get the correct ohm readings and go from there.
Old Jul 13, 2007 | 10:06 PM
  #19
qsportgoat's Avatar
thanks good idea
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Shainasmash
May 8, 2017 06:38 PM
Backwoods_badass
Aug 2, 2015 10:40 PM
Bulgin88
Aug 1, 2015 06:39 PM
Jul 15, 2015 02:07 AM
