newbe ? lt 80's
Old Nov 24, 2007 | 08:01 PM
onebigzj's Avatar
Default newbe ? lt 80's
?1
just bought 2 lt 80s. a 2000 and a 87. I think they should run better. hard to start. did a compression test and 85lbs. what should they be at? im not meathead. bilt sleds and larger quads 125 was normal unless head cut for race gas. would 85lbs make it run that bad? these are so small I LOVE IT!!!!!
?2
how do you fix the caster? one is fine the other is ugley. every thing looks tight.
how do I check the belt? does anyone know what the width is suppose to be? and loose or tight looking in the recoil space?
Old Nov 25, 2007 | 10:27 AM
LT80's Avatar
LT80 Expert
Welcome to the forums Meathead. [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
You are correct, 125#..You need freshened up.
The Camber is not correctable altho your spindles may need new bushings.
The belts wear forever and the thinner the better. You should service the clutchs. ie: (front)clean the rollers and check for flat spots. (rear) check the bearings and scuff the pads. [img]i/expressions/face-icon-small-smile.gif[/img]
Your understanding wife have a sister??? LMAO
Old Nov 25, 2007 | 11:12 AM
onebigzj's Avatar
thanks.
I read oem piston and rings are better than weisco. Iv always used weisco with out a problem! whats the diff? can you just rering or is it a new piston and ring? Do I have to remove motor to get to belt and clutches?
as for the sister. she has one but her mom named him paul. and not very understanding!!!!!!
Old Nov 27, 2007 | 09:48 AM
LT80's Avatar
LT80 Expert
Weisco's need a very careful break in. OEM's you install and go.
New piston too.
remove engine:: No.
JMiller
Oct 23, 2008 07:48 AM
Veryoldron
Sep 2, 2008 12:53 PM
CoachB47
Jul 30, 2008 01:18 AM
r6realtor
Nov 12, 2006 06:56 AM
funkyb
Oct 21, 2006 03:00 AM
