Semi auto trans problems?
OK.I tried the suggestion of changing the oil.I also tried adjusting the clutch.It is under the cover on the right side as you said it would be.After all of that I put it in reverse and it started to move out of the shop instantly,however the longer I drove it around the worse it got.Am I suppose to adjust the clutch with it running?I did it with the machine off.Thanks for all of your advise from eveyone.
Thanks,I did readjust it with the engine off.I am certain at this point it needs a clutch.I have yet another stupid question[img]i/expressions/face-icon-small-happy.gif[/img]o they make a specific clutch for one with reverse verses on without reverse?I mean in a car you are changing the gear and not the clutch,is it not the same on an atv?
No, generally they are all the same clutch, no matter if its a semi auto, or a full auto, with or without reverse. The only thing you may need to do is on the backside of the clutch pack, there is a snap ring & a gear, sometimes the gears can be different, but all you have to do is change out that gear from your old clutch to the new clutch if its different, (its not a wearable part, only the actual disks are) & you are set.
#15
