Two Brand New ATA 250-D ATVs Won't Start
Old Nov 5, 2008 | 11:07 AM
ghcoe's Avatar
Default Two Brand New ATA 250-D ATVs Won't Start
Seems that the GY6 auto chokes have issues. You may be having the reverse problem as noted on this site.
http://www.rc-trucks.org/gy6-engine-performance.htm
Take a look at.
4) Eliminate automatic choke
Lots of other good ideas there too...
Old Apr 1, 2011 | 07:00 AM
dyna's Avatar
Default help
Just purchased a taotao 250E and the suspension and ride are stiff and unenjoyable. Is there any thing I can do that won't cost an arm & leg to make the atv a pleasure to ride or is it the design of the atv it self. Thanks
Old Nov 11, 2015 | 02:21 AM
toatoanogo's Avatar
I just bought a TaoTao Rhino 250 (11/03/2015). After putting gas in it and setting the kill switch to the run position, It started- ONCE !!!- It wont start now. Fuel switch is in the on position, in neutral, brakes depressed, key on, clutch level squeezed, throttle engaged. It turns over fine just- NO GO. I will never buy another one of these pieces of Chinese junk. What should I do?
Old Nov 11, 2015 | 03:10 AM
Take the plug out, re-fit the lead, lay it on the head and spin the engine over to see if it sparks. Try a new plug if it doesn't. If you still have no spark check all wiring connectors for a loose wire. If it is sparking, check compression, if that is good, clean the carb out, some debris from assembly may have got in there.
Old Nov 11, 2015 | 09:19 PM
  #15
toatoanogo's Avatar
I took someone's advise to drain the carb bowl as they some times have an air lock- fired right up!
Old Nov 13, 2015 | 03:46 PM
  #16
patrick4653's Avatar
I had trouble finding parts for my son’s Chinese ATV and stumbled upon this web site. Has an easy to use parts lookup and you can call them for free tech help. I would recommend them to anyone.
Chinese ATV parts, Chinese Dirtbike Parts, Chinese ATV parts usa, chinese atv parts canada
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
RPK
Jun 8, 2015 01:05 AM
neilbedwell
May 31, 2015 11:11 AM
1000gade
May 27, 2015 12:37 PM
ragewraps
May 26, 2015 03:14 PM
