lt80 clutch mod
Old Feb 6, 2009 | 11:08 AM
coreyfatboy's Avatar
Default lt80 clutch mod
I was wondering on the clutch mod if you have to get to the weight by drilling the sides. I was able to cut the ends and grind them down to 180 g. But they are a little shorter than in the pix, will that be a problem?
Old Feb 6, 2009 | 10:08 PM
onebigzj's Avatar
as long as you didnt cut the pads. your fine!!!! and as long as they are the same weight your good
Old Feb 7, 2009 | 09:00 AM
what about the little rubber bumpers?
Old Feb 7, 2009 | 10:16 AM
I was also putting movable drive face together and i am using the best parts off of 2 quads , and i noticed that one of the the spacers that go thru the drive face is about an 1/8 in longer than the other. Is that going to cause a problem? Which should i use?
Old Feb 8, 2009 | 08:17 AM
LT80's Avatar
LT80 Expert
Throw the rubber things away.
Use the longer spacer. The shorter spacer has a washer. Don't put the washer on the longer spacer.
buddieboy
Dec 9, 2016 05:50 PM
QuadRiders
Oct 22, 2015 04:13 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
merryman
Sep 19, 2015 03:15 AM
