kasea 125cc will not stay running
Old Feb 25, 2009 | 04:59 PM
FordFan's Avatar
Default kasea 125cc will not stay running
Ok I have been on here before. I traded my riding lawnmower for this atv. When I got it the engine did not turn so I was told I (forget who on here) to dump ATF-automatatic tranny fluid thru the spark plug hole. It loosened it alot so regapped the plug cleaned it good spark. about a half an hour later spitting and sputtering and then it backfired. No smoke and stil wants to turn over but hessitates.
My question does the carb need taken off and cleaned? this is what I am thinking. how do I go about this.
Dave
Old Feb 25, 2009 | 11:56 PM
LynnEdwards's Avatar
Electrical Expert
This engine was frozen up? And now you are looking at the carburetor?
I would start by measuring the engine compression. Engines are not normally frozen up. This is usually a bad sign (I hope I'm wrong). A toasted engine isn't going to get fixed by adjusting/cleaning the carburetor. First things first.
Old Feb 26, 2009 | 08:46 AM
FordFan's Avatar
I understand that I thought and just figured it was toast until I added the atf fluid and it loosened the engine. How do I measure the compression? It seams that it has great compression just by turning the engine by hand. I just tried to start it about an hour ago and it almost stayed running.
Old Feb 26, 2009 | 09:11 AM
Electrical Expert
Use a compression tester from an auto parts supply store. It plugs into the spark plug hole. You crank the engine with the throttle wide open until the reading peaks out and read it.
A quick and dirty method is to remove the spark plug and plug up the hole with your thumb. Crank the engine. You should not be able to hold in the compression. Your thumb should get pushed off. Obviously this method is not as good as having a real compression checker.
If your compression is low, squirt in a little oil through the spark plug and repeat. If the compression rises you have bad rings or a scored cylinder. If it doen't rise substantially then it is leaking out the valves.
Old Feb 26, 2009 | 09:35 AM
FordFan's Avatar
Would it be worth replacing the seals? or the whole engine?
Old Feb 27, 2009 | 05:17 AM
FordFan's Avatar
Would a loose exhaust cause my problem at the connection of the engine and begining of the exhaust?
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dame0927
Oct 29, 2015 10:13 PM
jayking232003
Jun 9, 2015 02:54 PM
blaze_master
May 26, 2015 11:18 AM
