Please help getting quad running
Old Apr 26, 2009 | 05:39 AM
josephnyc's Avatar
Default Please help getting quad running
Hi,
I have a (less than 1 year old) Coolster ATV-3125B quad that wasn't used throughout the winter.
I went to start it (using a portable starter-booster) and it only starts with the choke fully on. I can keep it running by tickling the throttle and then for only a minute or so.
If I let go of the throttle, it will stall in a few seconds.
If I turn the choke off, it won't even start.
I checked that it's getting spark (visible spark with the spark plug cable attached to a plug held outside the engine) and fuel (removed plug and it's a little wet).
I opened the carb drain screw on the bottom of the carb and gas runs out.
I tried it without the gas tank cap off to make sure it wasn't a cap venting issue.
So, if my basic understanding is correct, it's either getting too much air or too little gas (most likely too little gas, I assume).
So, what is my next step?
I believe the bike uses a PZ22k carb.
Thanks very much,
Joseph
Old Apr 27, 2009 | 08:05 AM
LT80's Avatar
LT80 Expert
You need to remove and clean the carb. Yes too little gas, the jets are plugged IMO.
Old Apr 27, 2009 | 11:39 AM
josephnyc's Avatar
Default Carb removal
I was afraid of that.
Any tips/hints/tricks/suggestions on removing and/or cleaning a PZ22k from a Chinese quad?
Thank you,
Joseph
Old Apr 27, 2009 | 07:57 PM
mwillems85's Avatar
just pull it apart and put it back together the same way except clean but just take your time its pretty simple i was afraid of it the first time too but after 3 or 4 times it like riding a bike
SOLOLUCKY
Oct 4, 2024 09:09 PM
Hankey Pankey
26
Oct 18, 2020 03:50 PM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
pancake
Oct 21, 1999 10:43 PM
