lt80 clutch roller size/weight
Old Nov 21, 2009 | 07:29 PM
iron's Avatar
Default lt80 clutch roller size/weight
Looking for the standard clutch roller size and weight
Noticed when doing the crank seals the rollers were flat,plastic worn right through
Would this cause the quad to lose top end speed?
Thanks
Old Nov 22, 2009 | 09:47 AM
LT80's Avatar
LT80 Expert
Flat rollers cause alot of bad things. lack of speed, take off, and gouging of the variator and roller plate.
There are no aftermarket rollers for the LT80. You must use stock rollers.
Look at the variator and roller plate for gouges. Replace if gouged. If the rollers are that bad, I suspect damage.
buddieboy
Dec 9, 2016 05:50 PM
QuadRiders
Oct 22, 2015 04:13 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
merryman
Sep 19, 2015 03:15 AM
