lt80 front clutch
Old Apr 21, 2010 | 05:54 PM
JDCP's Avatar
Default lt80 front clutch
How do i fix the front key on a lt80 that has been ground away?
I guess the key was not aligned correctly when it was installed last
Thanks
Old Apr 22, 2010 | 07:52 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
The key can be turned around if you think a end got messed up a lil.
You'll prolly need a new roller plate (has the notch in it for the key).
Old Apr 22, 2010 | 08:46 AM
JDCP's Avatar
Thanks for the reply
I did get a new roller plate but the problem is the key is ground smooth
does the starter gear come off to get the key out??
thank again
Old Apr 22, 2010 | 09:18 AM
DAMONSQUAD's Avatar
thank again
yes, the starter gear pulls right off
Old Apr 22, 2010 | 09:38 AM
JDCP's Avatar
Thanks
I will give that a try
Old Apr 22, 2010 | 10:28 AM
LT80's Avatar
LT80 Expert
Sometimes the key is messed up a lil, you may have to hit it with a file to get the starter gear off.
Old Apr 22, 2010 | 10:43 AM
JDCP's Avatar
yes the gear is not wanting to come off I'll try filing
thanks
Old Apr 30, 2010 | 09:29 AM
JDCP's Avatar
Ok still trying to get the starter gear off tried filling. any other suggestions
Is there some kind of puller
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 15, 2015 10:48 PM
tporath
Jul 11, 2015 12:31 PM
200es
Jul 10, 2015 09:09 AM
Wnthunting
Jul 9, 2015 03:02 PM
