lt80 boggs
Old Apr 27, 2010 | 05:53 PM
pc3176's Avatar
ok mr. lt80. i found out that the port in question is the carb vent so i took the vacuum cap that the previous owner put on it off and wow! problem solved! i mean, are you kidding me?! three damned weeks of throwing everything i could think of and then some, and that was it! thanks for going back and forth with me on this issue. this machine was close to becoming an expensive boat anchor. just wondering, do you just throw a tube on the vent port and hang it down below the motor, or should it be held up out of the way of dirt. thanks again. my kids, and i especially, are very happy.
Old Apr 27, 2010 | 06:19 PM
LT80's Avatar
LT80 Expert
Umm, as you suspect, don't try adjusting the float. It'll cost you 19.95. Another fella in here just did all that. LOL
On the right side of the carb there are 3 holes. Closest to the motor is the vac supply to the petcock. The middle is the fuel supply. The front hole is the vent. If that's plugged, unplug it and see how it goes.
Old Apr 28, 2010 | 06:25 AM
DAMONSQUAD's Avatar
haha that was a stupid lesson for me to learn! lol. only good thing out of it is that the new part number from suzuki has the adjustable metal tab!!
Old Jun 15, 2010 | 09:39 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Hello everyone new to site... sounds like the quad is running rich if you take air cleaner off and runs better. thats gives more air,, try pinching off fuel line while running[up on blocks] and see if it run better as fuel is getting lower. if so try difference petcock assy. also you are going backward on needle clip if its run better with fuel pinched off also try clip in top groove which will cause needle to go further down giving you an leaner mixture.... NOW if it runs the same with fuel pinched off and don,t lean out before going dead than it aint an fuel problem.... But sound like from what you said it should run better when you pinch off line.....Just and ideal... try it and get back... thanks..
Old Jun 15, 2010 | 10:06 PM
  #15
Loved
Community Favorite
Haha sorry i mash send button to quick.. Do this with the air clenaer assy. on.. also the air bled hole in front of carb.venture could be clogged up... Please keep us updated.... Thanks for reading.... Good Luck....
Old Jun 16, 2010 | 08:14 AM
  #16
LT80's Avatar
LT80 Expert
LOL. 2 month old thread.
Old Jun 16, 2010 | 08:34 PM
  #17
Loved
Community Favorite
Yup.......
Old May 31, 2018 | 08:41 PM
  #18
Healey410's Avatar
1990 lt 80...Is this correct? the plug on the carb is where i replaced the petcock to do away with the vacuum hose. closest to the motor is the vent ?
Old May 6, 2020 | 10:15 AM
  #19
LT80's Avatar
LT80 Expert
Oh no.. That front port is the vent. That needs a hose on it. The hose runs up under the hood.
You're lucky anyone seen this. Best to start your own thread.
reevtd123
Jul 26, 2013 09:07 AM
bigdog04
Nov 5, 2011 03:53 PM
daquadfather
Jul 9, 2008 06:52 PM
rpappas
Jul 18, 2004 03:02 PM
660grizzy
May 18, 2004 08:59 AM
