88 Yamaha Breeze 125
Old Aug 17, 2010 | 12:04 AM
thevinstigator's Avatar
Default 88 Yamaha Breeze 125
Daughter has a 88 Yamaha Breeze 125 and the thing runs great, tons of parts still available and starts right up. The only problem is occasionally when shifting into reverse the quad stalls out, does it when hot and cold so I am not real sure of the cause. She pulls in the front brake handle when shifting and it still stalls out. Is there a reverse limiter that could cause this??? Anyone have any ideas where to look, sometimes she gets off and pushes it a foot then it will work and she thinks THAT is the fix. HELP
Old Aug 21, 2010 | 05:26 PM
Nobody else has had this problem?? Anyone know where to start looking?? I hate to start ripping things apart without having somewhere to start.
Old Aug 21, 2010 | 06:09 PM
Jaster94's Avatar
are the brakes sticking? is it centrifugal clutch or manual(because you said brake handle-curious if it was clutch instead). not sure if the shifting forks might cause it to grab 1st and reverse at the same time. i'm not a tranny guy(i'm really sorry)
sorry, i don't know about a breeze. food for thought though!
Old Aug 21, 2010 | 06:32 PM
Jaster,
This is an single forward and reverse tranny, but you are supposed to pull in the left handlebar (rear) brakes when switching from Neutral to reverse. I suppose there is some type of neutral safety switch and there is an actuator on the tranny lever to stop you from over revving while in reverse. I am just a little unsure what is what,
I was hoping someone would see this and report a simple cure.
Old Aug 22, 2010 | 09:01 AM
LT80's Avatar
LT80 Expert
I'm thinking maybe a fault in the brake wire or something to do with the safety system.
If you don't hold the brake on to shift it stalls..right (normally)?
So if a wire was to maybe be loose causing the brake light to "flicker"(so to speak) it'll shut it off when trying to put into a gear.
On a machine I just had in, if the motor was at too high of rev, it'd stall when trying to put in gear.
Good luck.
Old Aug 22, 2010 | 04:53 PM
I will look at the wires, and also try without using the brake lever. There is a switch on the shift lever and I am sure there are also some wires there, I will take a look in the next 2 days as I am off work then and then post my findings. Thanks for the pointers, I appreciate it.
Old Aug 27, 2010 | 02:25 AM
flatblack's Avatar
I have two of these animals and both have the same issue, there is a safety switch on the reverse lever that help to keep the gear box intact........when those go bad its all or nothing.
Old Jun 15, 2016 | 01:09 PM
CheriK's Avatar
Yes I have the same problem. .can anyone help?
Old Jun 16, 2016 | 02:53 AM
Is the brake light working? The engine will cut out if you try to move the shift lever without the brake light on. Those switches on the shift lever signal the F.N.R lights on the dash, and the engine cut out. If both sets of switches are working, the problem is in the wiring.
black_thunder
Sep 22, 2015 07:59 PM
CosmoM
Sep 21, 2015 04:57 PM
Sep 17, 2015 03:06 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
