150cc want crank
Old Mar 18, 2011 | 08:49 PM
Steven Miller's Avatar
Default 150cc want crank
Need help with a 150cc. Cleaned Carb, replaced autochoke and sparkplug. The engine will turnover good but will not crank. The last time it was running the engine sounded rough and was sputtering as if there was something wrong with the Carb. Could it be the timmimg or compression?
Thanks,
Steve
Old Mar 19, 2011 | 12:04 AM
LynnEdwards's Avatar
Electrical Expert
Thanks,
Steve
Do you have spark?
While the plug is out, hold your thumb over the spark plug hole and press down hard. Crank the engine. The compression should push your thumb off no matter how hard to push back. (This is a poor substitute for a real compression test, but it is easy to do...)
Pour 1/2 teaspoon of gas into the cylinder through the spark plug hole. Quickly put the plug back in and crank. Any signs of the engine firing?
Old Mar 19, 2011 | 06:39 AM
Very little compression. I can hold my thump down without it coming off.
Now what?
Steve
Old Mar 19, 2011 | 07:03 AM
snow racer's Avatar
Do a valve adjustment. If that doesent work you might need rings. Your comp shuld probly be around 100 psi.
pgamboa
Dec 24, 2023 11:52 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
dannytas
Sep 26, 2017 06:31 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
