Raptor 80 quit and wont start
Old Mar 26, 2011 | 03:51 PM
KEGRACING's Avatar
Default Raptor 80 quit and wont start
I have a 2000 Raptor 80 that my 10yr old rides. He was on it couple evenings ago, said he had been riding for about 10 minutes, and it quit. Said it kind of popped and backfired a little, lost power, then quit. Having to go from a 10 yr old's best memory.
I have pulled plug, is good. Has clean gas in the tank. He rides it quite a bit. Has good blue spark when grounding the plug, has compression (with finger in hole, no gauge reading). Turns over easy, but will not start. Tried spraying some carb cleaner in air intake, and still no start - not trying to start. Have checked the valves, and they are good, timing chain looks good. I have not taken carb off yet...
Any ideas or suggestions?
thanks
Ken
Old Mar 26, 2011 | 05:06 PM
Jaster94's Avatar
thanks
Ken
get a compression gauge, that'll tell you alot and they're fairly cheap.
Old Mar 27, 2011 | 08:58 AM
LT80's Avatar
LT80 Expert
I'd clean the carb to eliminate that aspect of the problem.
I agree, check the comp.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
buckshit
Sep 24, 2015 08:49 PM
sticky123
Jun 14, 2015 07:36 AM
1000gade
May 27, 2015 12:37 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
