dxl seriara eton 90 not working please help
Old Apr 5, 2011 | 06:35 PM
3145ninja's Avatar
Default dxl seriara eton 90 not working please help
the quad wont start and it is aggervating
Old Apr 5, 2011 | 08:17 PM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Moved your post to the proper area so you'll get the responses you need.
Old Apr 6, 2011 | 12:03 AM
LynnEdwards's Avatar
Electrical Expert
The first thing I would do is check for spark. Do you have spark? Do you know how to do this?
What is the history of the quad? Did it suddenly stop starting, or did this get gradually worse over time? Is this a spring time phenomenon after sitting over the winter?
Old Apr 6, 2011 | 08:51 AM
geoman's Avatar
Also, what do you mean by not starting? Is it not cranking over at all or does it crank and not fire?
I have a 2000 model, it has been great. The only issue I have ever had with it is the crappy airbox on them. I did pull the engine out this winter to rebuild it and freshen it up, ended up not getting to it, cleaned the carb, replaced the air box assembly, and stuck the motor back in.
Old Apr 7, 2011 | 08:15 AM
LT80's Avatar
LT80 Expert
Like mentioned...info please.
Have you tried anything to get it to go?
Old Apr 14, 2011 | 06:11 PM
PissAnt's Avatar
If not cranking check fuse under seat. Like mention to resolve a issue please let us know detail info. We'll be able to give better advice to get you riding again
hugemoth
Jul 20, 2020 03:28 AM
Ramman1
Jun 16, 2016 09:07 PM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
