LT80 Chain
Old Jul 1, 2012 | 07:57 AM
LT80's Avatar
LT80 Expert
ya..13/26 fits perfect which means others don't LOL.
What your going to need is a chain roller.
Place the roller under or over the chain and pull it tight. Put the bolt thru and mark where it hits the matel plate. Drill and mount the roller.
Old Jul 1, 2012 | 04:18 PM
sengle's Avatar
Ah - LT80- that explains it thanks!
Am I correct in thinking that if I go from a 12 to a 13 tooth front, I'll get a bit slower takeoff but a bit higher top speed?
Cheers from New Zealand:-)
Steve.
Old Jul 1, 2012 | 11:09 PM
LT80's Avatar
LT80 Expert
Correct.
Read up on lightening the rear shoes. That and roller weight and you will compensate for the taller gearing.
Old Jul 2, 2012 | 05:32 PM
sengle's Avatar
Thanks LT80. I have already serviced the clutches and now have 4 rollers. I haven't done the 180gm mod as my daughters are both new to this so don't want to scare them too early!
I'll add the roller and perhaps go to a 13 tooth as another option. I can live with slower take off if I go 13 tooth.
Many thanks.
Cheers,
Steve.
Old Jul 3, 2012 | 08:07 AM
  #15
LT80's Avatar
LT80 Expert
Steve, FYI: I consider the stock LT80 jerky on take off. The rear clutch mod seems to smooth it out.
It's not a wild speed mod.
Have fun.
Old Jul 4, 2012 | 12:26 PM
  #16
bentz2151's Avatar
I would most definetely put the tensioner on the bottom, because the tension is already in the top from the motor pulling, and it would put un-needed force on your tensioner and wear it out in a hurry, where as the bottom its not near as much force
Old Jul 6, 2012 | 07:27 PM
  #17
farm_boy420's Avatar
Default tight chain?
i had to loosen the rear end on the lt 80 to be able to fit my number 40 chain with 13 -26 sprockets. when i tighten my diff bolts back up the chain tightens back up and and i was wondering how much loose you guys got ?
Old Nov 14, 2022 | 09:19 AM
  #18
Camoweasel's Avatar
Quick question. Will the stock chain cover still fit if one decided to convert to 13/26 428 sprockets and a 428 or #40 chain?
mrtidy
Feb 3, 2016 05:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
