E-ton 40cc 2-stroke
Old Mar 14, 2012 | 10:22 AM
jp jr's Avatar
Default E-ton 40cc 2-stroke
My son has an e ton viper jr. 40cc pull start, to make a long story short, after replacing the coil and trigger module, i realized i only needed the cdi limiter box, which is a dis-continued part. It will intermitantly run if u just tweek the screw on the limiter (like it has an open spot inside) Runs great as long as it runs. Tried hooking the limiter wires together on the trigger harness, but will not run that way. How can I by-pass this, or is there anywhere i can find the limiter? The e-ton part num. is 700404. Wouldn't care to buy 1 if i could find it. Otherwise, need help! Thanks in advance.
Old Mar 14, 2012 | 12:19 PM
Jaster94's Avatar
i PMd you an Eton dealer. check it out.
Old Mar 14, 2012 | 01:06 PM
jp jr's Avatar
Should also clarify that i tried to just un hook the box and leave wires hang like tech guys have told me, but have no spark that way.
Old Mar 14, 2012 | 10:40 PM
LynnEdwards's Avatar
Electrical Expert
@ jp jr re: eton viper 40cc pull start:
I have a wiring diagram of this quad, but unfortunately there just isn't enough info from that document alone for me to figure out how this ignition system is supposed to work. It is not the standard generic CDI style ignition system used on most quads. Problems with this style of eton ignition system have been posted here before, but no solutions that I know of have ever been posted. I've searched the internet for info on how this system works before and now and have come up empty.
I'm hoping that someone else will be emboldened by my ignorance and post any little bit of info they happen to know. Knowledge can accumulate and get sorted out over time with just tidbits of knowledge/experience from a variety of sources. It is worth a try.
Sorry I can't be of more help...
Old Mar 15, 2012 | 07:10 AM
jp jr's Avatar
I appreciate the effort. At least I can get it to run by messing with the screw, just want it reliable.
NatePerz
Jul 27, 2015 03:27 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
Jul 7, 2015 11:00 PM
RickSoto
Jan 10, 2001 07:07 PM
OneDollar
Jan 8, 2001 01:42 PM
