LT80 lacking power and wont rev.
Old Jun 25, 2012 | 10:03 PM
tomanyprojects's Avatar
Default LT80 lacking power and wont rev.
Hi, I have a 2001 LT80 that has very little power and wont rev past about half throttle. I've tried lots including,cleaned the cluches checked the belt, new plug, new air filter, new carb, ckecked the reeds. the compression is good. when i got the quad the cdi was burnt out and had some other wireing issues. So I replaced the intire wireing harness with one out of a 94 LT80. Not sure if that the problem but it seem like a fuel issue.
any help would be awsome! as I am out of ideas.
Thanks.
Old Jun 25, 2012 | 11:30 PM
Also it is kinda hard to start when cold. It idles nice, but has some oilish stuff coming out of the exhaust.
Old Jun 26, 2012 | 08:09 AM
LT80's Avatar
LT80 Expert
How good is the compression?
Old Jun 26, 2012 | 08:17 AM
bentz2151's Avatar
check the petcock for a partial clog? if you have spark and compression it must be fuel, or your thumb lol
Old Jun 26, 2012 | 10:20 AM
the compression is just over 100, the spark seems strong and it is getting lots of fuel to the carb. the throtle asembely works good and is smooth. clutch works smoothly aswell. I had the fly wheel off and cleaned it up. Is it possibale that I put it back on 180deg. out? also would the pipe cause it to be that bad is it was pluged? It seems to flow well but does spit out oilely stuff. It was sitting for about 4 year befor i got it. and yes it has fresh gas. It seems to be getting worse (reving less and less) But sounds good at a idle.
Old Jun 26, 2012 | 03:32 PM
Just an update. I burnt out the exhaust with a tiger tourch untill in pretty well stoped smoking, Wow what a diference! It came alive! It still seems some what under powered but is 100 times better than what it was. Still hard starting when it cool to. It will alomost spin the tires off the line with my 70 pound 9 year old on it. Any easy (and cheap) power adders that anyone would recomend? I'm going to freshin up the top end as well.
Thanks for the help.
2quiker
Mar 22, 2022 08:36 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
antiguogrumete
Sep 5, 2015 03:41 AM
