Lt80 clutch overall any tips
Old Nov 16, 2012 | 09:51 AM
  #21
Gsi-mark's Avatar
Originally Posted by LT80
Yes, 1 nut (17mm) on the rear clutch.
When you get that off you'll find a big nut FYI:: the big nut is left hand thread.
The cover is that big aluminum thing that you argued with to get off.
So there is one nut that holds cover on then a left hand one then will shoes come out ready for modding
Old Nov 16, 2012 | 02:42 PM
  #22
LT80's Avatar
LT80 Expert
Yes, one nut for the rear clutch removal. Then under hub (cover) you'll find the big left hand thread nut. I use a 1 3/16 or 1 1/4 depending on the year.
Then the clutch pack will come off. Then remove the 3 springs then 3 cir-clips and the shoes will come off.
Remove those rubber bumpers (you'll see)..
Old Nov 17, 2012 | 02:01 AM
  #23
Gsi-mark's Avatar
Ok jack sorry for all questions do I remove rubbers then cut shoes down
Old Nov 17, 2012 | 07:37 AM
  #24
LT80's Avatar
LT80 Expert
Once you get the shoes off, you'll see the rubber things.
Old Nov 17, 2012 | 07:41 AM
  #25
Gsi-mark's Avatar
Do I remove them jack then cut the shoes down and put back together
Old Nov 19, 2012 | 12:08 PM
  #26
Gsi-mark's Avatar
Clutch shoes off jack need ur help on clutch cover re fitting which bits go we're as it all fell off and got mixed up
Old Nov 19, 2012 | 07:37 PM
  #27
Brian Adwell's Avatar
On mine it went like this -
Big spring
Clutch pack
Big nut (press in hard on clutch pack to get nut started,lefty tighty,righty loosey)
Hub (COVER)
Big spring washer (the cup lookin washer sits inside of it)
Nut (Fat lookin nut that threads are recessed on one side)tighten and your done!!!
Old Nov 19, 2012 | 09:14 PM
  #28
LT80's Avatar
LT80 Expert
Crap.. I replied to this, this morning..or so I thought.
Ok, it's like this (I'll presume you have the clutch pack together and on the post)::
Splined hub-fiber disc-clutch drum (what your calling the cover I think)-fiber disc-flat metal piece-big spring washer-splined umbrella-nut.
Old Nov 20, 2012 | 02:01 AM
  #29
Gsi-mark's Avatar
Cheers disc facing in or out jack
Old Nov 20, 2012 | 08:20 AM
  #30
LT80's Avatar
LT80 Expert
The metal disc goes either way, the big spring washer goes cup side in.
