eton viper 70 4 sroke with no spark
Old 08-27-2013, 09:47 PM
bitney's Avatar
Installed new cdi and still nothing. Going nuts. I need someone smarter than me to help.
Old 02-07-2015, 04:39 PM
mlsmka5's Avatar
Default question in regards to anomaly?
Originally Posted by Jaster94
once in a while, a new NGK spark plug fixes them right up due to the anomaly of not firing under compression. i've done the checks and rechecks and cleanings before to no avail, tried a new plug and BAM, it ran. sounds like you're very thorough. no need for the pill.
I have a Eton viper RX4 70cc that wont start. One thing I noticed is that while turning the engine over it has no spark but once I release the starter button the plug starts to fire. Which seems very strange to me considering how normal vehicle's work. Is this normal?
Old 02-10-2015, 11:44 PM
Jaster94's Avatar
Huh? Please explain again, if starter is released & quits spinning, how can you see spark? I'm trying to get a better understanding,
Old 02-10-2015, 11:46 PM
Jaster94's Avatar
So you're grounding against the jug while cranking to test for spark, right?
  #15
Old 02-10-2015, 11:49 PM
Jaster94's Avatar
Bitney, sorry I've been offline for a while, computer crashed so I went to an iPad to get back online, how's your quad?
  #16
Old 02-11-2015, 03:00 AM
The sparking only when you take your finger off is quite common on bigger Quads, and I've never solved it. You get used to blipping the starter button as one of those sparks will "catch" and the bike will then run OK until you need to start it again. Some say it is dirt on the trigger coil inside the alternator housing.
  #17
Old 02-11-2015, 08:26 AM
Jaster94's Avatar
I've not solved it either, the other thing I haven't figured out is why a spark plug won't spark installed but when pulled to check will spark. Never can find a ground issue but suspect a double internal ground within the spark plug, just don't know ,...
vtech
Help With Forum Software!
09-02-2015 05:59 PM
hueby
1) Engine problems..
08-29-2015 08:34 AM
Jr Wagner
08-21-2015 07:56 PM
mbkirk
08-14-2015 08:20 PM
mbkirk
Technical and How-To Articles
08-14-2015 08:12 PM
Quick Reply: eton viper 70 4 sroke with no spark
