gasket help
Old Feb 9, 2014 | 03:00 PM
fishlips's Avatar
Default gasket help
this was apart when I got my 89 lt80. I looked at the parts diagram and it dose not show a gasket on the back of the reed block.
is there one that goes here.
also I cant tell if there is an o ring here or do I need another gasket
Old Feb 9, 2014 | 04:54 PM
DAMONSQUAD's Avatar
o'ring on the carb side, the other side is molded in, cant be replaced, use some rtv or make a paper gasket if needed. i would prefer rtv tho
Old Feb 9, 2014 | 05:08 PM
fishlips's Avatar
thank you for the help like most im trying to rebuild this for my son. the parts diagram only shows an o ring on the spacer. do I use the same one for the reed cage.
Old Feb 9, 2014 | 05:23 PM
Lt Granddad's Avatar
The raised rubber lip outer edge serves as a seal top picture. Looks like u may want to take reeds off and clean the rubber if that ain't pitting to ensure proper seal of the reeds, inspect reeds while off too. Was there a plastic spacer shaped like 2nd pic it presses against that side of reed block between that and carb it will require an o ring between spacer and carb. Will prob have to get from suzuki dealer hadn't found one that matches at an auto store
Old Feb 9, 2014 | 05:32 PM
LT80's Avatar
LT80 Expert
I does look like there is some pitting around the reed.
Like mentioned, only 1 o-ring and that goes in the black plastic piece (it's called a insulator).I use a lil grease to hold it in.
Old Feb 9, 2014 | 05:43 PM
fishlips's Avatar
I ordered new reeds so I will clean that up. thanks. I'm sure I will have more questions as parts come in and the build progresses.
Old Feb 9, 2014 | 05:46 PM
LT80's Avatar
LT80 Expert
If that reed cage is pitted where the reed seats, you'll need another.
Old Feb 9, 2014 | 05:56 PM
fishlips's Avatar
yes just checked and its pitted pretty bad dose $45 sound about right for a new one or is there a better aftermarket
Old Feb 9, 2014 | 05:57 PM
DAMONSQUAD's Avatar
if your interested in used, i know i have a few laying around. i just have to check if they are pitted, but i pretty much already know they arent
Old Feb 9, 2014 | 06:40 PM
fishlips's Avatar
pm sent
1ArmBandit
55
Oct 14, 2015 09:03 PM
tysonbully
Sep 28, 2015 02:30 AM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
