2006 Baja 90 trouble
Old May 20, 2014 | 08:22 AM
Kevcules's Avatar
Default 2006 Baja 90 trouble
Hi guys......I bought my son a baja 90 in 2006 and it has worked real well for him! I was thinking of selling it but its making a seemingly drive train noise now and I never sell anything not working. I was sure it was the chain and sprockets because the front sprocket was toast but after replacing them, same thing.
When you start moving , it starts to make a clank, clank, clank that speeds up as you speed up. It sounds like it's coming from the wheels (when I lean over as I drive) but I checked the front wheels and even changed the bearings....no good. I'm going to disconnect the drive chain and rev the engine to hopefully eliminate the rear axle. I'm thinking it's from the clutch or transmission, something inside the covers. Any thoughts on what it could be?
Thanks...
Old May 25, 2014 | 08:22 AM
Kevcules's Avatar
Any ideas anyone?
Old May 25, 2014 | 08:38 AM
LT80's Avatar
LT80 Expert
CVT or shift model?
Old May 25, 2014 | 01:25 PM
Kevcules's Avatar
It's automatic....no shifting.
Kevin
Old May 25, 2014 | 02:00 PM
LT80's Avatar
LT80 Expert
Well we could guess all day long. Better take the clutch cover off and see what's going on.
Let us know what you see that could be making the noise. Check to see if the clutch nut(s) have come loose, etc.
We'll go from there.
The CVT's are easy with parts galore.
Old May 25, 2014 | 06:19 PM
Kevcules's Avatar
Thanks for posting LT80...... which side is the clutch on? I was going to crack open both sides ,but will start with the clutch side i guess.
I've never had to work on this bike before, just chain and sprockets. It's been pretty solid!
Here is a few pictures of both sides.....
thanks
Kevin
Attached Thumbnails 2006 Baja 90 trouble-baja-lh-side.jpg   2006 Baja 90 trouble-baja-rh-side.jpg
Old May 25, 2014 | 06:49 PM
LT80's Avatar
LT80 Expert
OK, it's not a CVT like I was thinking.
I'm not much help on this one.
Try posting in the china section. It may get more views.
Old May 25, 2014 | 07:02 PM
Kevcules's Avatar
Ok thanks anyways.... I also posted in the Chinese section with no replies yet...75 views.
Kevin
95wolv
Sep 27, 2024 12:00 PM
akguy31
Aug 31, 2019 04:34 AM
mrtidy
Feb 3, 2016 05:00 PM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Clint Russell
Sep 25, 2015 03:20 PM
