Lt80 starter or something else wrong?
Old 11-12-2015, 02:03 PM
LT80's Avatar
LT80 Expert
Originally Posted by littleboots
Of course it was running fine before I decided to mess with it. Well not fine. It would run but only with choke on. So I figured pilot jet was clogged seeing it wouldn't idle when you stopped and the choke was off.
And now a flood occured. Get it up and running and then see how the starter/idle/etc works. Maybe you did get it going...lol
I also noticed the arrow on the new belt I installed. Well of course this thing runs opposite of how you would think. Do I need to flip the belt around? I'm guessing I should seeing they put arrows on it for a reason.
The belt will be fine as is.
Old 11-13-2015, 02:37 PM
patrick4653's Avatar
I bought a used 110cc Chinese atv and the carb was shot. I search on google and found this site which I think is awesome. Great detail on the parts, pictures and all the specs you need to match the part you’re looking for.
Chinese ATV parts, Chinese Dirtbike Parts, Chinese ATV parts usa, chinese atv parts canada
Old 11-13-2015, 05:43 PM
LT80's Avatar
LT80 Expert
Which would be helpful if the LT80 was a chinese thang...Lol
Update: Patrick4653 is a spammer. Go away.
Old 11-13-2015, 06:34 PM
littleboots's Avatar
OK so I got her running. thanks LT80 and LT Grandad. Bike fired up after I cleared out fuel from cylinder. I ordered a new starter from ebay seeing the starter is temperamental and I don't want to be stranded in the middle of glamis trying to tow a quad back.
Now my problem is clutch issues. I'll start a new thread after I do some research. It revs really high and doesn't seem to want to allow clutches to move (so it sounds) it only does about 15 mph right now and revs really high. I only have 4 rollers in front and cut rears down to 180G. Maybe I didn't put something back together right. I also didn't change the plate on the front clutch and it did have some groves in it.
  #15
Old 11-13-2015, 07:25 PM
LT80's Avatar
LT80 Expert
It sounds like the notch in the roller plate and the key. You'll have to take it apart and see.
The key/notch has to be aligned. If you did align them, it can move durring installation of the belt/spacer/outer face. It happens.
When you're in there, spray a lil WD40 in on the starter bendix.
  #16
Old 11-16-2015, 08:59 PM
Ok. So I'm wondering if I should start a new thread. But here's a video of the clutches and I want to make sure they are turning the correct direction and everything else is ok.
I also took everything off and noticed that the key isn't pulled all the way forward so maybe it's a different key or wrong key? Well there is a gap and it seems that the front clutch is just barely grabbing the keyway. Any help on this thing? I also am not sure if the front clutch needs to be replaced due to the grooves or if I can leave it alone.
Can you see the gap? Gap is about 1/16"
  #17
Old 11-17-2015, 02:00 PM
LT80's Avatar
LT80 Expert
LOL.. It's turning the correct way.
Your variator (where the rollers sit) is scrap as is the plate that covers the rollers.
The key is sticking out as much as any do. Once the front is tightened down, it don't move.
Go here for parts. Cheapest I've found.
http://www.powersportswarehouse.com/.../I11I1118E1390
  #18
Old 11-17-2015, 02:35 PM
I found the variator plate but what's the part number for the cover... Or the other part you said I needed? Thanks jack. Just didn't seem like the key way was sitting out enough.
  #19
Old 11-17-2015, 05:14 PM
LT80's Avatar
LT80 Expert
59301~ variator
13271~ roller plate.
Hankey Pankey
05-01-2018 01:33 PM
gorylewis
27
10-04-2015 05:22 PM
firsttimerider
Technical and How-To Articles
08-27-2015 02:09 PM
1966F100
Sport Quads
08-22-2015 06:51 PM
Hankey Pankey
08-17-2015 05:01 PM
Quick Reply: Lt80 starter or something else wrong?
