New top end?
Old May 3, 2018 | 01:37 PM
SharpTJ's Avatar
Default New top end?
My kid has 70cc bike that seem to run well until a couple days ago... now it will only idea while choked. If I try to ride it, it will "catch" very once in a while and begin to accelerate for a few feet, then lose power. It will not run un-choked at all.
I can also lift the rear end and it seems to run fine while accelerating and I can even un-choke it while WOT. But as soon as it returns close to idle it dies.
DOES this sound like a compression issue? I was thinking carb, but the inline filter is clear and the most noticeable issue is only under load.
edit: Let me add that I did a compression test, but the results were so off that they lead me to believe the gauge may be faulty since the bike will run at all...
Old May 3, 2018 | 05:59 PM
LT80's Avatar
LT80 Expert
Ya gotta clean the carb first. Dirt can come from vent lines too.
Old May 4, 2018 | 11:46 AM
SharpTJ's Avatar
Carb cleaned and no spark arrestor... At least it idles now I choked and will move with my 4 year older in it... It still loses all power under any moderate load.
Compression shows 30 psi max... Would it even run on that little compression?
Old May 4, 2018 | 03:01 PM
LT80's Avatar
LT80 Expert
I'd think no.
Old May 5, 2018 | 07:55 AM
I had a Honda 70, two wheeler in to "fix for Christmas" a couple of years back. Did run but no guts at all, and quite bad to start, checked compression, less than 20psi. When I took the cylinder off, the rings were so worn they fell through the cylinder when I put them in to check ring gaps. Fitted a Chinese cheapo cylinder kit, ran fine after that. However a sudden drop in compression indicates either valve problems or a piston seizure. Try adjusting valve clearances first.
Old May 6, 2018 | 12:38 PM
SharpTJ's Avatar
It's a 2 stroke, so no valves. I used my buddies gauges and my gauge is, in fact, faulty. 110psi and 15% leakage on leakdown.
Took carb off again and played around with it. I found that if I put my fingers over the 2 small holes where the air box connects to the carb, it runs perfect.
Where should I start with the air screw to adjust it?
fordblaster
19
Sep 21, 2004 02:56 PM
DarkManX
Sport Quads
8
Sep 18, 2004 04:36 AM
Straps250r
Aug 7, 2003 08:24 PM
mudmunster
Feb 27, 2002 03:49 PM
Need4Speed
Dec 16, 2000 08:23 AM
