need some help havin oil problems
ok I have been having problems with the oil coming out of the little hole on the air box (i hope you know what i am talking about) and we changed the oil and it was still doing it and we did it again and it is still coming out quite a bit. so could you tell what the amounts of oil are, the guy that we bought the four wheeler from gave us these amounts (1500cc oil 700cc tranny) and I would like to know if that is right or close to what you guys use for yours and if it isn't could you tell me what you use.
When you fill it, only put in 1.5 quarts of oil. Also, do you have the crankcase breather update? Check out www.cannondaleriders.com alot of good info there.
ok thanks alot got it figured out when we changed the oil it wasn't all coming out and when we refilled it we were always putting more than need back in and overfilling it again thanks though
