Cold Weather Problems
Old Dec 1, 2002 | 05:51 PM
54warrior's Avatar
Default Cold Weather Problems
the last time i went riding, everything was fine when i put it away. went out today to do some riding in the snow, and it starts, and idles fine, but when you stab the throttle, it starts popping, backfiring, and such. I thought that it might be the fuel filter, so i changed that, no difference. the temperature outside is between 20-30F. added some dry gas after that, hope that solves it. just wondering if anyone else has had any probs like this???
thanks
Old Dec 1, 2002 | 07:17 PM
Guest
Guest
Posts: n/a
Where the header connects to the engine, the nuts might be loose. Also, you better check all the electrical connectors and plugs.
josh
Old Dec 3, 2002 | 06:53 PM
54warrior's Avatar
It was the fuel, just as i suspected. decided to spend the 35 mins to remove the tank, drain it, and put new fuel in it, it runs like new. feeewwww
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
ltrmc02
Jul 22, 2015 04:50 AM
hondarider1234
Jul 21, 2015 11:53 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
