Toy Hauler Shopping - Advice / Oppinions
#21
I agree with all thats been said already. My buddy bought a 22' Weekend Warrior towing with their jeep cherokee, was within the weight ratings empty but by the time it was loaded up with everything, way over loaded. He ended up getting a Ford 350 dually, no problems now. Cut your losses, go with a 350 or at least 250, 3/4 or 1 ton.
#22
I have 20' carson enclosed trailer with trailer brakes that I pull with a 32' motorhome love it. I use to pull for one season the trailer with my f150 4.6 with load leveler springs. I never had a problem but I new if I did not get something bigger it would shorten the life of my truck. I have a freind with a f250 diesel and he pulls a 30' 5th wheel and nothing slows him down. I guess what I'm trying to saying is you could make do with what you have, but you will soon relize you will want something bigger to pull with.
#23
#25
For what it's worth:
My buddy had a simple enclosed trailer that he used. he attached 4 old Army surplus stretchers to the walls, set to fold against the wall and hang from a strap hooked to the roof. he's load up the toys and haul them wherever, and once the toys are out, setup a camp table and stove, and sling down the stretchers as beds. Worked really well, too!
A custom window in the front let in a lot of light and airflow when needed. We pulled this behind his Nissan pathfinder with a V6 with no problems.
#26
Rance Aluminum Trailers has a few that may work for you, they are very well built but still light in weight. If you can get by with a 7' wide V nose it will pull easier, use a simple handtruck type dolly to load the quads sideways. 18' foot would be plenty long enough for 4 quads and plenty of room for gear, check the spec sheet on this trailer, it's under 2000#.I have one of the Renegade models and am happy with it.... http://www.rancealuminum.com/esnow718ER.htm
jrooker6
04-23-2016 07:36 PM
