400 ex throttle adjustment
Old Jun 16, 2000 | 11:17 PM
redridaz513's Avatar
how do i fix the throttle glitch on my y2k 400 ex??????
Old Jun 17, 2000 | 12:36 AM
EXtreme-'s Avatar
boy am I glad I copied this on word perfect!
Start by removing the black air intake boot on the back side of the carb. Look into the large hole and the choke will be visible. Beyond the choke, work the thumb throttle and you will see the "slide" moving up and down.
At full throttle, the slide should be seated all the way to the top (disappearing from sight). Take your finger and check for further movement if there is room and adjust the cable at the thumb throttle till the slide remains at the top position at full throttle.
You can bet the ranch that there will be room to raise it on a 2000 model!...probably at least 3\8ths of an inch. Re-install the boot and let her rip.
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
dougn85
Aug 5, 2015 07:20 AM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
ghost civic
Jul 30, 2015 04:09 PM
Roadglider09
Jul 30, 2015 09:21 AM
