off topic -chevy truck motor
Old May 4, 2005 | 06:37 PM
paulie83's Avatar
Default off topic -chevy truck motor
hey a little off topic here but maybe someone can help?? i have a 350 its bored 30 over with high comp pistons, mild stage one cam ,roller 1.6 ratio roller rockers, 202 fuelie heads ,edelbrock intake ,edel brock carb , headers etc etc my questions is i just took the heads off and the ends of the pushrods ( the top by the rockers) where crushed !! i am also using pushrod guide plates. i think the wrong pushrods and they werent hard enough?? anyone else have any ideas?? i believe they are stock lenght any help is appreciated!!!!!
Old May 4, 2005 | 11:50 PM
Doctorturbo's Avatar
GOT BOOST!
In all my years of building and looking at SBC I have never seen "crushed push rods." Was there wear from the guide plates? If there was, that's the problem. It got thin from the wear and collapsed. Was there any valve problems like interferance? Was the push rods bent?
If you can get a picture up I might be able to tell you more.
Old May 5, 2005 | 07:49 AM
paulie83's Avatar
hey ya i think that when the motor was built the stock pushrods where put back in and the like you said the guideplates wore them out!!
Old May 5, 2005 | 09:04 AM
garyc660R's Avatar
The guide plates would never see the end of the pushrod....the sides below the top....possibility. With a mild cam hardened pushrods are usually not necessary.....but you never know the age of the pushrods. My guess would be wore out pushrods or valvetrain geometry problems...maybe wrong application on the rockers asuming they are not bent. If they are bent you could be looking are some clearance problems. Did you loose the heads from improper lubrication?
Gary
Old May 5, 2005 | 01:06 PM
swampadder's Avatar
You have some kind of clearence problem. Make sure the valves didn't hit the pistons. If the heads have been milled there may not be any clearence between piston/valve.
Also check for coil bind. Once you can find where the clearence prob. is then you will know what steps to take to solve it.
Old May 5, 2005 | 08:13 PM
paulie83's Avatar
the valves apear to be ok there are no marks on the pistons im kinda of thinking the roller rockers are the problem anyway i have the heads at a machine shop so hopefully i will know tomorrow what the problem is!!
Old May 6, 2005 | 01:10 AM
GOT BOOST!
Can you post some pictures?
Old May 6, 2005 | 07:25 AM
paulie83's Avatar
ya i can do that do you want pics of the pushrods??
Old May 6, 2005 | 11:00 AM
GOT BOOST!
Yep, close-ups of the P rods.
Old May 6, 2005 | 06:03 PM
paulie83's Avatar
alright the machine shop just called and it turns out the heads i bought which where supposedly for a 350 are actually off a 327 so they are going to completly redo them and set them up for my application
