do you have to use the clutch?
I have always used the clutch every time i shift i heard that thats how your spose to do it and i have heard its ok if you dont every once in a while if you forget to pull in the clutch, and i have heard your not spose to to shift. any replies will be apreciated
The effects of not using a clutch are long term. I would try to use the clutch as often as possible. I see people mostly not using a clutch when they are racing, because they need a full grip to hold on. I recently replaced the bottom end of my quad and needed new 1st -4th gears and am not looking forward to doing it again.
cdstang
Aug 31, 2015 07:52 AM
