TIMING
Old May 15, 2000 | 08:41 PM
brandon's Avatar
Glad to see you got it. I was thinking it had to be something in your ignition, a bad ground or loose wire or something. I have had to adjsut my crab slides for idle, so you cna do it that way. Let us know if you tell a difference with that advancer.
Old May 15, 2000 | 09:24 PM
Backcountry's Avatar
It's been my experience that Banshee motors have done well with from 4 degrees Adv. to 7 degress Adv. This is on motors that may be ported, but are only seeing upper 8's for RPM's. I would also reccomend that the maximum adv. that you run with pump gas be limited to 4 degrees, and STAY on TOP of your jetting. Getting a tad towards the lean side with more advance is a ready recipe for detonation. Pocket shape(combustion) influences this as well, wider flatter pockets require less ignition advance. Each motor has been different, so a little test and tune is necessary. As with everything, I reccomend taking notes of each change and try to test it each time, timed runs on dry asphalt is the best.
Old May 15, 2000 | 10:14 PM
blue_banshee's Avatar
well i remember when i went to 3degrees on my timing, i tried going up a size jets to 290 and it was too much fuel so i went back to 280's. just thoght u would like to know that
Old May 16, 2000 | 07:05 AM
millhouse's Avatar
Thanks fellas... OhtonRacing, I am going to check into that idle screw kit. Let you fellas know how good that new timing and delta-v reeds feels when I do a plug check...
Sjrpp
May 2, 2023 03:59 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
