Best clutch for a banshee??
Old Dec 12, 2003 | 01:38 AM
bad350twin's Avatar
Default Best clutch for a banshee??
all my buddies run Toomey,Barnett, or factory clutches!
Old Dec 12, 2003 | 10:36 AM
AlkyBurninX's Avatar
Well all my friends run the KG clutch factory Kits. They take the abuse of TT racing well. We are all running 65-75hp. The whole Kit is about $75 for fibers steels and springs. The spring tension is stiffer than stoc and easy to pull.
i said the FZR isn't needed because it is quite expensive from the factory. The difference is the width of the fiber. You do away with the cushions and the FZR fibers are as wide as the banshee fiber and cushion together.
Old Dec 13, 2003 | 08:06 PM
Halfliter's Avatar
My friend had real good luck with White Bros fibers. I think because they had deeper grooves and the oil had more room to go. I'm glad I read this thread because I want to look into the FZR clutch. Thanks DaBeechMan.
Old Dec 14, 2003 | 08:10 PM
sandbomber's Avatar
I ALWAYS USE THE STOCK CLUTCH & MIX THE SPRINGS (BARNETT & STOCK) HAVE NEVER HAD A PROBLEM WITH SLIP OR HARD TO PULL. SAME SETUP ON DRAG BIKE WITH LOCKUP.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
