WHATS THE BEST CARB FOR 2-STROKES
Old 01-06-2004, 05:18 PM
bansheeesmoker's Avatar
Default WHATS THE BEST CARB FOR 2-STROKES
dunning and hill shooting a little sand dragging mild to wild porting milled head v-forve reeds bored 39m-stock kienien .75 bore prolite piston with coating.i also run a air box and a knn filter, mid range pipe.
Old 01-06-2004, 05:20 PM
oh yea its a 95 cr500 in a 86 250r frame, the only thing stock is the frame and brakes!!
Old 01-07-2004, 02:16 PM
DaBeechMan's Avatar
depends on the fuel your running...carbs are designed to run specific applications. Example: You can put a 39A/S on an alk cr500 with a fuel pump. Its not going to do sh*t for fuel flow because the inner fuel circuits in the carbs are too small to feed your motor. Thats just one reason why you run different carbs for different applications
Old 01-07-2004, 06:56 PM
I was waiting for your response beech,c12 and I plan on running a 20 shot of N.O.S.next seasion. What do you think the best carb would be? I have a ftz booster carb makuni 39mm would that help,I could use the booster to adjust for hot cold weather and elevation instead of re-jeting.
  #15
Old 01-07-2004, 07:08 PM
Sheesnojoke's Avatar
The 39.5 PWK works great for my ported 94' Cr500.I don't know what kind of work you have done,so I can't say that your engine will like it.My portwork was done by Eric Gorr.Like they said it all depends on where you ride and what is done to the motor.
  #16
Old 01-09-2004, 11:12 AM
50021's Avatar
Kiehn, Carbs for two stokes are good, my friend has one on his 250r and it hauls @***
  #17
Old 01-09-2004, 01:42 PM
DaBeechMan's Avatar
Id run bigger then a 39.9 on your 500. A easy carb to throw on there would be a 40.5 that esr sells. Its a decent carb that is setup half way decent.
I wouldnt run methanol through it though.
  #18
Old 01-10-2004, 11:29 PM
dragracer789's Avatar
One of my friends has a 44mm mikuni. Not the best carb but big. (he had to have it bored, yes)
  #19
Old 01-11-2004, 12:22 AM
DaBeechMan's Avatar
They make mikuni's in 44's that do not need to be bored. You can find them for sleds all day long for next to nothing
GregM
07-29-2015 09:41 PM
NatePerz
07-27-2015 03:27 AM
ghost civic
07-27-2015 03:15 AM
Ask the Editor
12
07-21-2015 06:57 AM
07-07-2015 11:00 PM
Quick Reply: WHATS THE BEST CARB FOR 2-STROKES
