Thinking about a drag ATV
#41
Hey Beachman,
I went up to the drags again tonight, and did a little inquiring about the track.
The official length is 375 feet.
Tonights winner was a tick over 85mph, and he pretty much dominated the field.
I took a good look at most of the Banshee's that were there.
They all were "cleaned up" stock chassis's, with minimal chromolly tubing added, and extended swingarms with a racing axle. Most were running alky.
I didn't see anything that was all that dramatic.
The winner was supposedly running one of the 420 cheetah engines.
#42
If that's the case you could build a Banshee similar to those, or even a bit better, for 10k easily. 3k for a decent used banshee and that leaves 7k for a swingarm, engine mods and other changes. I would think that would be managable.
I'm sure a 250r could also manage it but from what I read they would need more custom engine work to get the same kind of power as a 400-450cc banshee. So unless you can fabricate yourself it would probably cost more.
#43
sounds pretty attainable. Did they run ET or just heads up and if they did do they get time slips? Either way that 7mm might be a decent ride for them guys then, if not i wouldnt go less then a 10 or 12mm cheetah. Better to really kick their a*s then to just nudge them.
#46
ya.
heres 1 that ive been wanting to do but never have enough money.
i've always wanted to do a suzuki gsxr1100 street bike engine in a quadzilla 500 frame, o ya and on alcohol. that would be sick as h#ll
